[langtitle=da]switch from Dish 500 to Dish 1000.2[/langtitle] | SatelliteGuys.US
Newty1
3
south central OH.
[lang=da]Im switching from a dish 500 to a dish 1000.2 that is hooked up to a 625 receiver to 2 tvs. what switch will I need for the extra coax from the 129?:confused:[/lang]
I think you're asking what you need to do to get the 625 to see the additional satellite? All you need to do is run a checkswitch. If that isn't what you are asking please reword.
I'm wondering since there is going to be 3 satellite feeds instead of 2 I will need to run another coax for the 129 will I need some other kind of switch for this to hook into?
Nope, no switch (as Matt said) and no need to run another wire. Just run it to the receivers and use the DPP separaters where appropriate (for the dual tuner receivers).
Satellite spliter
Help with 622 remote setup
