thanksYou can get 2 HR24's from Solid Signal, I believe.
I guess you are worried about if the server goes down you would lose your recordings? If not, you can use the DTV app as backup until a replacement server would be sent out.thats ok with me
I think the only way to get the two HR-24's is to buy them. Would DTV even activate the HR-24? DTV would send out either the HS-17 or HR-54, Mini's and the new Gemini with built in streaming apps for new installs.If the slowness of the HR24 is a concern, your main receiver could be an HR44 or HR54, while the HR24 could be a secondary receiver. Since this setup includes a Genie DVR, you would have to pay for Whole-Home DVR.
In comparison, two HR24 receivers do not have a mandatory WH-DVR fee.
I love that I can record as much as I want at same time on stream. No issues with 'oh crap I only have 4 tuners and have 6 things to record'You might want to consider Directv Stream. I was a satellite customer for 20 years and went to streaming last fall. It takes some getting used to, but I'm happy I made the switch.
Big Guy,
Go with the HR54 and a Client or HR24 ....
A client is Usually fine as lone as its all on the same system.
Sometimes you can get wired or wireless, depending on your situation.
Good point ...If the requirement is separate playlists in each of two rooms, then the best recommendation is an HR54 and HR24.
why go that route the bill won't be any cheaper than if they had an HS-17 and 2 mini's. id'e take the g2 over the hr24 anyday. looks like it's only has 2 tuners vs 7 tuners a 500GB HDD vs a 2TB HDD and no 4k service. plus a 2 year contract on thatYou can get 2 HR24's from Solid Signal, I believe.
we were told the other day that there pushing the hs-17 with wireless boxes and one gemini if we wanted it. we asked about the c61k minis. and the rep said they were not giving those out any longer they want to go all wireless and use the hs-17 as the hub as she put it. she also said that there rarely giving out the hr 54 any longer. so there pushing the wireless setupBig Guy,
Limited time offer
