Legacy Quad? | SatelliteGuys.US
Legacy Quad?
lawman1627 said:
Ok, thanks for the info, guess I will look for a DP twin on ebay.
i'd go with a DPP twin, that way you can use it with or without your DP34, use seperators to dual tuner receivers, and use the built in switch if you need a third location... i just browsed around ebay, and the price difference wasn't that much
Few questions about dual tuner DVRs
622 install
