light 6 foot dish w/ C Band LNB on a Sg2100? | SatelliteGuys.US
signal.quest
176
Near Scranton, PA
I have a 39" offset dish w/ KU LNB setup nicely to receive 72W - 125W w/ an SG2100. This might sound crazy, but do they make a 6 foot offset dish that is constructed just as light as my 39"? How about a C band LNB that would mount on it? It would be nice to swap my 39" for a 6' and get some C band. I would rather not get into Actuators, V-Box, etc... Thanks.
If they made one that light the weight is not what you have to worry about. It would be the wind load on the dish. With a dish that size the motor would think it had a dish that weighted close to 100 lb. on it, the motor might hold it up but it would not turn it.
most 6 foot dishes weigh way much more than a 48" dish
That 6 footer I got is probably 40-50 pounds
How to adapt Direct TV dish to FTA
GEOSATpro Firmware Updates Available: DVR1100c / DSR100c / DSR200c
