linear LNBF | SatelliteGuys.US
linear LNBF
johnny_baker
75
is there any way to make a linier lnb pic up circular 91w.. i read somewhere that u can make the frequency higher??:confused:
A linear LNBF CAN be used to pick up circular signals!!!!
I use mine on 119w and it picks up NASA TV!!! Does not work for GOL TV on 110w in this area! It all depends where you are in the country and what the adjacent satellites are!
ALWAYS worth a try :)
i have the sC dual beer can look alikes, will these work and what tp should i put them on??? thanks PSB
Try a blind scan on 119ºw then try a blind scan on 110ºw see what pops up!
The Freq. will be way off but as I noted above they CAN pick up some circular signals :)
Probley not worth my wile than PSB unless i gonna get 10 or more..i don't think i can get 119 or 110 because i am in fronth of a hill..Got any other recomendations for my setup? SC dish and lnbs and viewsat extreme??? hav a smal 18; on bev and doesn't move..
Hills do not usually block satellite signals unless you are right up against the hill and you live up north! Mountains maybe :)
i live in st. john's newfoundland canada, and the hill is like 20 feet from my dish
haha sucks.. i'll try the scan for 82 and see what happens.. thansk
Trx-1520
I'm a new guy! help me hack
