Linkbox - LinkBox 8000HD Boot Problem | SatelliteGuys.US
Linkbox LinkBox 8000HD Boot Problem
Achebee
106
9
Honduras
I have a boot problem that just started with a LinkBox 8000HD.
It boots to a solo #8 on the panel and will not start up.
Anyone know of a solution or can you link me to a thread concerning this..??
Thanks in advance for your help, HB
It's a little late to reply to this but maybe it'll help someone else. Sounds like a boot-loop issue. Try doing the ERom Upgrade for the 8000HD that you can d/l from LINKTV MEDIA
An ERom upgrade for my 9000i fixed my startup problem so it might just help you.
