Lipsync Problems on Weather Channel HD | SatelliteGuys.US
StatsGuru
12
I'm noticing lipsync issues with Weather Channel HD on both my H20 and HR 20. Both have sound going from the box to the TV via HDMI. Anyone else notice this problem? The SD version of the Weather Channel seems to be fine.
NBC was way off last night, both OTA and on SD Local from DirecTV.
yea noticed this morning....heather in the studio was ok but she was talking to someone at a remote site and they were "godzillaing" lol....luv that term.
I thought I noticed the same thing at one point this morning, but then I looked closer and it was fine. Sounds like it might be a TWC thing, rather than a D* thing, if it's varying from one segment to the next.
The 'lipsynching' effect isn't uncommon. If you look around at the other channels closely, you'll notice some others. Part of it has to do with the transfer speeds of the various cables you have connected into your audio/visual system. Best thing to do is get a receiver that has an adjustment for this.
Spreadsheet of Channels
Considering move from Dish to DirecTV
