Little River, SC 29566 | SatelliteGuys.US
Ajax95
8
Hey Guys, could someone who has the satellite finder software post the birds I should be able to see from here with a 90cm Fortec dish and Invacom Univ. LNB.
Also, is anyone who posts or lurks on this board in the Myrtle Beach or Little River area. I've noticed a lot of FTA dishes going up in the last year.
Fill in your zip code, and this program (web site) will generate a nice PDF file customized just for you.
GeoSatFinder - Satellite Finder Calculator © Satellite AV
Any birds that are 30° above the horizon, should be easy to receive.
Those from 10° to 30° may be receivable, as you gain experience.
Of course, any buildings or shrubbery which block your view, will prevent reception.
For programming, check out these web sites (in order of easiest to hardest):
Menu of Channel Lists - FTAList.com (even has a list "by language")
http://www.global-cm.net/MPEGlistKuBandUS.html (has other lists for C-band)
North & South America - LyngSat
With a motor, you should be able to get 30w to 129w with no problems, if you have no obstructions blocking your "view". I'm abit NW of you and can get all FTA sats in that range, though 58w changed some of the lineup and have problems getting the added ones at the high end (probably need to adjust the dish a bit).
BSC621-2 C/Ku LNBF ?
having problem picking up Galaxy 10R
