lnb help | SatelliteGuys.US
lnb help
rcwilcox
300
2
i have an eastern arc setup but i am using three dishes one for each sat with DP single LNB's One of my LNB's has excessive drift. I have no more spare single LNB's but I have extra twin LNB's as in for a dish 500. All this feeds in to a DP34. My question is if I put a twin on one of the dishes and it is aimed at 61.5 will it work? Will it ignore the otherr half of the twin? I know I will have to realign but will the configuration work?
Yes you can do it that way. I have done this several times in the past.
FCC approves Dish's plans for high-speed wireless
