I found a USB satellite TV tuner with a DVB-S support from eBay, and while I looked on the side, I found that it says "lnb-in" and "lnb-out". Does that mean that you hook LNB's in there or is there any methods for that? Please reply....
How would you do that?It means that there is an input for connecting to the LNBF and also a loop out for connecting to another tuner (with limitations).
Make sure the card also processes DVBS2. Think you would be disappointed quickly if the card only receives DVBS.
When you mean card, I didn't mean that... I was talking about the USB tuner from eBay(that I looked at when searching "usb satellite tuner") that functions the DVB-S support.Simply connect a coax cable from the LNBF on the satellite dish to the LNB IN connector on the card.
Well, I'm not getting it yet...(I might get it if something's wrong with my Hauppauge 950Q) I just want more info on buying satellite tuners. The tuner from the link "trinidex" showed me is in DVB S2...USB satellite tuners will receive unscrambled, free channels from any satellite source as long as the tuner supports the format that signal is transmitted in.
Look at the specifications of the tuner and make sure it can decode the modulation types of the channels that you want to receive. Typically the channels on Nimiq and Echostar are scrambled and you cannot view, but sometimes a few channels are unscrambled.
I would recommend at minimum to purchase a unit that tunes DVBS and S2.
USB tuners and PCI tuners are more difficult to set-up and typically have glitches. Since this is your first satellite system, I would recommend that you get your feet wet with a system based on a set top box receiver first until you learn the technology then migrate to a computer tuner after you have some experience.
Limited time offer
