LNB power? 129 project | SatelliteGuys.US
Greg Mueller
Munich Oktoberfest
851
86
Datil, NM
Forgive my ignorance of the correct terms....
Do all LNBs put out the same amplification?
I'm still working on putting together an improved mount/dish for that pesky 129 bird.
I am thinking of taking of the 129 LNB off the Dish 1000 and just moving it over to another dish, which will be either a Dish 500 or a larger dish if I can find one locally (I think I might have found one). But I was wondering if all LNBs are the same? Do some put out more "amplification" than the unit they give you with the Dish 1000? Would a "stronger" LNB (if there is one) be worth what ever it would cost?
Is it possible to get to much gain? If I were to get a 1 meter dish with a stronger LNB, could I "over drive" the VIP 211?
All the LNBs are the same. It is the size of the dish that focuses more signal on the LNB.
The only issue I have read about with DBS satellites is if the Dish gets to large (like over 3 meters) that you start to see the individual satellites in an orbit location (like if you were looking at 110, you would have to move the dish between E6 and E8).
Dish Network HD Locals quality?
Periodically loosing Los Angeles HD Locals
