Nope, I went from a SL5 LNB to the new Reverse LNB 3 LNB DISH and all I needed to do was pop the old LNB off, the new LNB on then go inside and resetup the Satellite settings. It went through found the new LNB and all was well after that.![]()
I am trying to set up a temp installation I have a slimline with a sl5 LNB with a signal of 95%. I have a r22-200 when I put in the sl3 I bought on eBay I get no signal. How can I test the sl3 LNB
Jack
I went from SWM SL3 to SWM SL5 yesterday without needing to adjust anything. Although 119 signals are low...
He went from a 3 to a 5, not the other way around. You are right though. I went from a 5 to a 3 and was still getting signal strength readings on 119 until I redid the sat setup.There is your sign - You need to re-run the sat setup - or restart the receiver (red button) or through the menu - If you are still showing the 119 - you have not reset the sat receiver to the correct LNB -it still thinks it has a SL5
Limited time offer
