LNBF acting up? | SatelliteGuys.US
LNBF acting up?
turbosat
9,003
82
Oneonta,AL
3-4yr old BSC321 (or was it a 621?) lnbf acting weird today, getting signal levels of only 10-40, but the quality readings are usual and normal, 75-95. Seems to be scanning in everything , but for some reason the signal level is near to nothing. This is one of those old gray plastic cheapos I have had three years or more but has always worked ok. I factory defaulted the reciever just for fun tonight, and doesn't seem to make any difference. Still have good ku , just unusual readings. Maybe I'll swap out for another style tomorrow and see what happens, this one may be about to barf.
What satellite and receiver and dish size??
The block amplifier may be failing.
Looking forward to info after swapping. See if low Signal Level is the STB tuner or LNB amp.
Pro96-its my Vantage box, and the problem shows up on all the satellites I've looked at, on ku side. (shows 10 signal and 80quality on abcnewsone feed lol)
If it don't rain again today I will try another lnb. Haven't had any lightning lately so I don't think it was that, possibly just weak/failing part in the lnb.
Opinions of which motor to buy
200 hunderd audio channels on 103w ku.
