lo settings | SatelliteGuys.US
lo settings
CbandLover
161
Ok, I finally got my Fortec Lifetime Ultra! Long time coming, but finally did it. I was playing in the menu and trying to set it up with my Primestar LNB It has h/v out so I am just using V for now. What settings should I be using? I am pointed to AMC9, a few thing popped on the the blind scan on standard lnb, but it says 0 Programs. I have a 36" Fortec with universal lnb, but I want to see if this Primestar is good for anything. Thanks in advance.
Should be Standard, then change the L.O. to 10750
Maybe nothing on AMC-9 V right now.....
Thanks Pete. Appreciate it. Should the power scan take about 10 minutes or so? Is this right? Or am I doing something wrong?
Sounds about right, I just put on an Invacom LNBF (Universal) and a scan is taking around 20+ minutes on some satellites !
84E with a Zinwell(sp) 4X3 switch on a Lifetime Ultra pointed at G10R.
Works for me :) 10 mins sounds about right. Try scanning for all or it you can move this dish try pointing at another sat.
Good luck!
unlock Philips DSX5500?
Can't decide. Pansat 2700A or CoolSat 4000 Pro
