Local Channel Failed "HD Test" | SatelliteGuys.US
JayG27
12
Our local news station (KRCG) had a test for the HD conversion this morning and it failed through the dish. They are going to fix that before the 17th right?
Just a small point, its not the HD transition, its the digital transition. Digital does not require HD, but HD DOES require digital. But in answer to your question. Yes hopefully things will be worked out between your local station and Dish before the switch is switched, whether it be the 17th or pushed back to June 12th.
Lost locals till reboot
eastern arc self upgrade
