Local Channels OTA on what Transmit? | SatelliteGuys.US
mcrimm
2
I'm having trouble finding 2 of my local over the air channels that are on 8.1 and 8.2. I found 9.1 on transmit #37. Where do I find the other 2 if they don't show up on the automatic scan?
Thanks,
Mike
Do they show up on a TV that has a digital tuner?
It is extraordinary that you would have two adjacent channels so I'm a little suspicious about the numbering.
As we have almost no clue where you live (outside of the channel 9 radio frequency), we can't tell you what you should expect. Have you tried tvfool.com or antennaweb.org to see what all is available?
Are you using lots of splitters on your OTA antenna?
Thanks,
Mike
Yep, plug your locale into TVfool and see what stations are available and it will give you the "real" channel numbers and you can plug the "real" channel into the the add locals feature you've found and then you can tell if it's receivable.
Acer
New Smart Cards
Need help, please read, Canal 1 Internacional (Ecuador) free
