Is there a device out there to where I can stream local channels only for free and one that's legal so that i won't have to fumble through mutable apps
thanks i'll have t o investigate it. kinda looks like dishes air t.v. i think its calledHD Homerun. Works with an OTA antenna.
yea i seen that thread
You should make it clear whether or not you have OTA reception. If not, something like the AirTV or HDHomerun will be of little to no use. Without a media server (and probably even with a media server on iOS devices), some sort of app will likely be required.Is there a device out there to where I can stream local channels only for free and one that's legal so that i won't have to fumble through mutable apps
You only need a media server for recording on a Hdhomerun. Most TV's support dlna, so you don't need a separate streaming box.You should make it clear whether or not you have OTA reception. If not, something like the AirTV or HDHomerun will be of little to no use. Without a media server (and probably even with a media server on iOS devices), some sort of app will likely be required.
Are you looking to make your own streams or play someone else's (or both)?
Good to hear the Fire stick works well, since Best buy now gives them away with a Hdhomerun purchase.The DLNA works very well. I stream to my Sony Blu-ray player and a Fire Stick from the HD Homerun and it's fantastic.
You may need a media server to transcode the MPEG2 that comes from the Connect products. DLNA support does not imply MPEG2 support. DLNA allows the streaming device (such as a Roku) to tell a server that it can't do MPEG2 and the Connect products have to punt.You only need a media server for recording on a Hdhomerun. Most TV's support dlna, so you don't need a separate streaming box.
Now you are reaching, bringing up Roku. The conversation is about TV's. FYI some Rokus can handle the Mpeg 2 stream with the Roku media player.You may need a media server to transcode the MPEG2 that comes from the Connect products. DLNA support does not imply MPEG2 support. DLNA allows the streaming device (such as a Roku) to tell a server that it can't do MPEG2 and the Connect products have to punt.
The thread is literally about streaming of local channels. It wasn't established what the source of the stream was nor the streaming device to be used. The conversation turned to the HDHomerun as a possible source. Assuming that the goal was to stream to a SMART TV is not sound as they are neither required nor necessarily desirable as streaming devices (as evidenced by the massive success of Roku and Fire TV devices and the fact that Best Buy is giving away a streaming device with HDHomerun purchases).The conversation is about TV's.
When it is established what the streaming device is, then we can restrict the playing field but that doesn't appear to be the case at this point.
Then again, it hasn't been established that the TS has reliable access to OTA signals so the HDHomerun suggestion may be academic.
It is important not to outrun the TS.
I'm not assuming anything. An initial assumption (absent important details that still haven't been shared by the TS) was made by comfortably_numb that OTA might be available (the premise on which a HDHomerun recommendation could be made).So now you are assuming?
You've assumed that OTA is indeed available, that the TS is using a DLNA streaming TV and more.
I guess you could say that I assumed that because Best Buy was delivering HDHomeruns with Fire Sticks, it is clear evidence that your streaming SMART TV argument was full of holes. If everyone already had a suitable solution there would be no need to bundle yet another one. I don't have direct insight into why Best Buy is doing this bundle but it seems pretty obvious that they're not assuming what you're assuming.
In post #9 you declared that most TVs support DLNA.Did I ever say "Smart tv".
Wrong again, I have a non Smart Samsung TV that supports Dlna.In post #9 you declared that most TVs support DLNA.
I think you would agree that "TVs that support DLNA" = "SMART TVs" and logically your statement could also be read as "most TVS are SMART TVs".
Limited time offer
