Local channels | SatelliteGuys.US
Local channels
Leesburg
11
I live in a senior's mobile home community about 75 miles from Orlando, FL.
I have a ShawDirect (Canadian) dish and receiver, everything is working fine.
Is there an EASY and INEXPENSIVE setup so that I can receive local TV in addition to the Canadian channels I get now?
Any help or advice would be greatly appreciated.
it depends on your TV and location. If you have an HDTV with and ATSC tuner, a simple $5-10 antenna hooked directly to the TV may be all you need. plug in your address to a site like TVfool to see what channels you can receive and what type of antenna is necessary
Thanks for the quick response. The search indicates that I could be getting several "local" channels. I have a new HD TV. If anyone can suggest an inexpensive antenna, please let me know.
