Local Channels? | SatelliteGuys.US
Local Channels?
reubenray
1,524
1,302
Bella Vista, Arkansas
Can I turn local channels off and on if needed? I don't need them at home, but I could use them on trips in my RV. I have several trips that I am still in the spotbeam.
Yes just login your account and unsubscribe or subscribe as needed. Consider a OTA adapter for home if you can have a antenna.
I have an OTA adapter and a big outside antenna at home. I also have a four tuner Tablo connected to the antenna. I am setup for at home. But when I take trips in my RV that are in my spotbeam there are usually no local antennas/stations close by. This is when I would want to turn on the local channels. My travel schedule this year will be for April, May and part of June and then September and October. I could have the locals turned off for 7 months and on for 5 months.
Even if you're outside of your spot beam it's easy enough to temporarily change to the locals where you are. I preferred doing it by chat session instead of a phone call until they added the feature to the phone app for my "Outdoor" account.
Random Question
2 Tb SSD on Hopper 3
