Local Standard Def vs High Local High Def channels | SatelliteGuys.US
txfeinbergs
80
2
Guys, I am really confused since the local high def Dallas channels were added last night. Do I now get the local standard channels and the local High Def channels, or just the local High Def Channels?
Are the High Def channels now mapped down to what used to be the local standard def channels or do I need to use the 6000 range channels. If they aren't mapped down, is there a way to do that?
Thanks. (it isn't exactly possible to tell the difference between a standard def channel and a high def channel until there is high def content on (tonight during prime-time I ought to be able to tell what is what).
Nevermind, found my answer. Apparently lots of people are having this particular question. Sorry for the extra thread.
More HD and I want it NOW!
622 Sound And Pic Problems
