TuxCoder said:It almost sounds like you (DP1962) or your retailer were talking about your locals as delivered through satellite from Dish Network... those are not in HD at this time. If that's not what you meant above, then you can safely ignore this message.![]()
yup...DP1962 said:Shall I assume that dfergie is referring to an OTA routed through a Dish Network HD receiver
No and yes. If you have a TV antenna and your HDTV has a digital tuner then you could receive local OTA in HD, but of course the 522 is not playing any role for HD.DP1962 said:I have a DVR 522 receiver and was told by my Dish Network retailer that my local channels would be HD if hooked to a TV with a HD tuner, is this correct?
Yes, if you have a TV antenna connected to it you can receive local OTA in HD.DP1962 said:Would this even be the case if I had the Dish Network HD receiver?
Limited time offer
