Looking at Dish | SatelliteGuys.US
Looking at Dish
lgjmb
8
I'm looking into getting Dish network, but am not very familiar with it. I've done some research, but would like to know a few things:
I want to get high definition. Will the VIP 222 receiver be ok to receive all MPEG 4 HD signals? Or should I look at the 722 DVR?
Is the current satellite dish due to be replaced like the Directv Slimline dish?
Thanks for your input.
All the VIP recievers use MPEG4. In terms of the dish its hard to say for sure but eastern arc appears to be a ways away which needs a different dish. Most HD content is currently on 129 or 61.5 which usually means a Dish 1000.2 is used. With internationals a Dish 1000+ is used which gets the 118 bird as well.
A replacement sat for 129 is set to go up at the end of the year so the dish 1000.2should be used for quite some time still.
You definitely should look at the 722 DVR...it's a DVR, and accommodates External Hard Drive storage.
What are the best current E* freebies??
is my 622 going out
