Looking at going HD | SatelliteGuys.US
Looking at going HD
Yespage
17,672
18,000
Ohio
Well, with Setanta morphing into Fox Soccer Plus, I'll be seeing a $15 credit on my bill as I won't be subscribing to FS+. So, that means going HD is probably a good idea. Looking around at the threads here has be almost scared to death to do anything, however. :eek:
So, here are the questions:
- In NE Ohio, will I need a second dish to get the HD channels, or will they just need to replace my existing dish.
- I see they may (are?) moving their HD channels to another satellite. Would this have any impact on me going to HD now verses later after the transition, i.e. what dish or dishes I'd need?
- I'll need to step up the receiver. I current have one and will just replace the one I have with an HD receiver. What is the difference, if any, with the 722 and the 722k? Leasing isn't cheap, but buying isn't the greatest either. I'm assuming that the only benefit of buying the receiver is to not have to extend my contract, correct?
- Is there any other consideration I'm not thinking of?
I currently have a Duo625 and I believe am just into the 2nd year of my two year contract. Any help would be appreciated. Thanks.
Wow! 83 views, not a single response. Was it something I said?
Ok.....they will replace your dish for a 1000+ .
If they move the hd chans to another sat and you wouldnt be able to receive your chans in hd they would come out and adjust your dish for free so you could get them, dont worry about that.
The difference between a 722/722k is...the "K" has a OTA output and a coaxial output (the 722 doesnt have that) on the back upon request.
If you only have ONE rcvr duo or solo, the fee is incl in your programming package. You would only pay extra rcvr fee's if you have more than one rcvr.
Hope that helps!
Actually the OP would get a 1000.2 or 1000.4 plus an extra dish if needed depending on where their locals are.
The plus dishes just add internationals and some western locals may still be there.
Thanks for the information. Just saw the info 922 and it may be coming out soonish, but I think that'll be a bit rich for my blood... and I've pretty much integrated my laptop into the HT, so 722 will do.
Dish 1000.2 Upgrading to HD 722K Receiver
Setting up 3 tv2 remotes to work simultaneously
