Neutron Founding Supporter Original poster Supporting Founder Nov 7, 2003 18,716 1,124 Texas Sep 25, 2016 #1 I need a 1000.2 dish with the LNB that will work with our Wally receiver for our camper. Would like to get a tripod for it as well. Sent from my iPad using SatelliteGuys mobile app
M mikeH_dishNetwork SatelliteGuys Guru Dec 23, 2010 127 39 U.S.A Sep 25, 2016 #2 Have you checked with your local retailer to see if they have the equipment for your RV? Will you be using it while the RV is in motion? If not it sounds like you will be wanting our model DISH 1000 Tripod Manual Portable Dish (TR-6100).
Neutron Founding Supporter Original poster Supporting Founder Nov 7, 2003 18,716 1,124 Texas Sep 25, 2016 #3 Will only be using it while at the RV park. Sent from my iPad using SatelliteGuys mobile app
M mikeH_dishNetwork SatelliteGuys Guru Dec 23, 2010 127 39 U.S.A Sep 25, 2016 #4 With that being said you will want to get the TR-6100. If you can DM me I can better help with this.
