Looking for a c-band tripod mount | SatelliteGuys.US
O'Doyle
157
103
Ridgeland, South Carolina
Hey all...I am looking for a tripod mount for my 10ftr, I have the remains of the original pole is 6ft.9in. so I figured I would pour a slab of concrete (deep enough of course) and use the tripod mount on top of that..looked on ebay, no luck, craigslist, no luck, so I figured I would ask here. Thanks...Chris
Just weld three gussetes onto the bottom of the pole. Extend them below the pole to get extra height, or use piles to raise the assembly (can be integrated with a slab. This would allow adjusting for vertical if things shift etc. Is this an equatorial mount (polar mount)?
good idea! will see if I can locate someone local to do the welding. Thx!
There's a pretty neat setup here: Dish ID Help Needed
I've got this for my 10', which has quite a bit of adjustment:
The measurements:
Hughesnet dish to FTA.
Designing a system
