Looking for a motor... | SatelliteGuys.US
We had some discussion of this a while back.
When you throw around terms like "available" and "reasonably priced", I think the answer becomes: "NO".
...and as I recall, the $200 or $300 solution someone brought up, wasn't anything I'd put a 6' dish on, either!
I've mentioned this in the past: I would like a USALS controller to hook to a stock H-H BUD motorized mount.
Right now, I'm afraid the best solution is either an H-H or screw-jack motor, combined with the very nice Gbox v3000 from Sadoun.
That's what I'm hooking up, and if there was a better solution, I'd be using it!
LoTech
The answer is NO. It is not available in the USA that I know of.
Follow Anole's suggestion. It will work like a charm and won't tell the difference.
How to use the existing cable line?
FTA HD Channels
