Looking For Answer | SatelliteGuys.US
Looking For Answer
Morgan
Can someone tell me if you can use a Star Choice Dish with a Bell Express Vu receiver ? It is a 3100 model receiver. Also if you can where do you find the direction to point the dish ?
sort of
The LNB's on the StarChoice aren't compatible with Evu. You would need a DBS LNB to get ExpressVu.
In terms of pointing it, need to know location. For MN, it is almost south, but you're are will be different :)
