Totally disgusted….and in need of expert help/advice
I had a 625 installed last week in place of my 508. I have tv1 connected via coax to my tv with output selected to channel 4 (have local channel on 3). I have tv2 connected to the same tv via coax. Even though the tv1 connection is identical to the way I had the 508 connected, I get faint rolling white/herringbone like lines. If I change the output to channel 3, they disappear. But I can't leave the output as channel 3 because when the I connect the antenna feed and tune to channel 3, I get the local channel and not the satellite. Tv2, tuned to channel 60 is fine. Why am I having this problem with the 625 but didn't with the 508 or 4900 or 2800? Is the coax output on the 625 different from those receivers? Could the mechanical switch on the older units make that much difference in isolating the channel frequency? Is there some kind of filter that I can use to correct these lines? This is the 2nd 625 that I have tried in 2 weeks. I think that I would enjoy the flexibility of the 625…………..IF I can use it in my setup.
