Looking for FTA FAQ links. | SatelliteGuys.US
ken2400
1,309
144
Central NY State
Just looking for some good FAQ links I can send people that are intersted in FTA. I am looking for basic ones that talk about defs and equipment.
Ken
I see fta-help.com has the beginnings of a glossary on there. Cascade, for LNB you might need to add "Downconverter" even though it's not part of the acronym. -- "Low Noise Block Downconverter" since that's the essence of the device, to downconvert a frequency block from ~11-12 GHz down to ~2 GHz and less.
fta-help is looking good Cascade, but looks like a lot of work, keep it up!
Nice start Cascade. Looks like you have a good idea. :up
I can't stand frames though. :(
http://members.sparedollar.com/mbpa/fta800x600.jpg
Even at 800x600 screen resolution I have to scroll left and right to see the main page content. The title frame is cut off too. Either make the text tables relative to the screen size or lose the frames totally. At most I would go with a NAV frame on the left and main frame on the right.
Don't shoot the messenger, but thats just my $.02.
I honestly don't know the first thing about HTML - it's just a mock-up right now but if you can make it nice then go for it.
Edit: I think the width is OK, the frames for the title aren't.
Anyone who uses 800x600 ought to buy a new monitor or use large fonts.
Manual entries on 3618
Add on LNBF for big dish
