Looking for help with a Channel Master list for MeTV | SatelliteGuys.US
Larry1
1,594
138
Port Hope, ON Canada
Well my friend with his C-Band dish has not been able to tune in MeTV or THIS since the change over to 101. I only have Ku myself, so am asking if someone could help me out with a Channel Master file with MeTV and THIS for 101. I am planing to go out to help him in another week and would like to have a Channel Master file that I could load into my GeoSatPro 1100c for I would know I have all the parameters correct to make it easier to search for 101.
Thank You....Larry
Yep... thats all
Once I have that tuned in with my receiver, then I can put his receiver back in and program in the channel. Just wanted to make sure all the parameters are correct for I am scanning for the channel and not for blank space.
If so here is a Geosat file with all the channel removed EXCEPT what is on 101W C-Band
The satellite list is from the Geosat
Note this will wipe all other channels out
Thanks, (that was sure quick) I will backup my settings before removing my receiver and loading that file. It will make finding MeTV and THIS a lot easier when I go over there.
I knew I had a file with some C-Band stuff on it (when I updated thelist) so that was easy to find.
good idea :)
Venture Actuator company
Zero for 12 - Finally a "YES"
