Hi folks,
I was recently given an old DirecWay DW4000 dish, and I thought it would be fun to enter the world of FTA. This is my first post.
Here are a couple photos of the dish and LNB (LNBF? I've looked the difference up but I don't quite understand it). I've stripped off the transmitter unit and taped over its input to the feedhorn, just to block any debris from getting in.
Also, I can't post links yet, but if you Google "direcway dw4000" the first result is exactly what I have.
At this point I'm just curious to experiment, and I'd like to find out as much as possible about what I might be able to receive with my dish. Unfortunately I live in the woods, so only a narrow area of the sky is visible to me, but since I'm just doing this for the fun of it that doesn't worry me too much. I think the swath I can see is about the 80-85W range. I'd be thrilled if you could tell me anything about my equipment and my possible targets.
(I also just picked a Twinhan 1028 PCIe card up on eBay, since a computer-based tuner seemed like a versatile option. I'm having trouble getting that going, but I don't think this is the right forum to ask about that, and I wanted to make sure I had good satellite/dish/LNB[F] information first.)
Thanks!
Thanks!
