Looking for motor recommendation | SatelliteGuys.US
Pepper
DVR Addict~Mad Scientist
8,464
1,490
Satsuma, AL
I'm looking to add a motor to my current setup which is a Microyal MRX1000 with a 1-meter PrimeStar dish and a diseqc switch connected to a couple of fixed dishes. Can anybody give me a recommendation on the best value for motorizing this? I would like to buy from one of the Satelliteguys sponsors that has the best deal, or used if somebody has one they aren't using anymore.
I don't see any motors in the Equipment Reviews section, whoever has one should really consider writing it up.
50mm tube
Where can I find this adapter? I saw a picture of it by clicking the link, but I did not see a price for it. I have a 1m Primestar dish and would like to try it on my SG2100.
As a follow up...
It says it can handle a 1.2 dish... But is that sales hype or can it swing it for a few years w/o burning up? I'd rather spend a few bucks more and get a heavy duty motor if I need it.
As Zig Ziglar says, "When you spend too much money you waste a little money. When you send too little money, you waste it all."
thanks
I had my 1 meter Winegard on a HH100 for a little while, it fit ok. I believe the hh120 has the same shaft diameter. Maybe you were looking at the clamp size for the lnbf 25-35-40-50mm?
Pansat 3500 Scan Problem
Help with BrasilSat1 in Miami
