Looking for RBN-LIVE FEEDon IA5 | SatelliteGuys.US
soonersat
26
2
Norman Oklahoma
Hello All,
I just got my CaptiveWorks CW600S Receiver and a Fortec Star Dish and all I want to originally do is get the system up and locked onto the RBNLive Audio Feed on IA5.
My location / zip code is 73072 and I need some type of 'quick-start- instructions to get me up and going on this bird, the simpler the better... AND.. do I have to feed my receiver to a t.v. or is there another method, as I have no immediate plans to watch.. ...only listen..
Also..thanks for all the patience and help on board this site..
Here are the angles to the satellite, what kind of LNB are you using now?
Code:
                        Norman, OK 73072
          Latitude 35° 12.642'N Longitude 97° 28.380'W
                       Sat Name Sat Lng Az(t) Az(m)    El  Skew
                           IA-5   97.0W 179.2 173.7  49.1  -0.7
        Satellite Finder is (c) Copyright 2004, P. Lutus
DFreq. 11966
Pol. H
SR. 22000
For RBN TV
You will need a TV to be able to point your dish!
After entering the above you will have to use the above angles to point the dish. You will HAVE to be able to see a TV from where the dish is, you will be watching for signal quality ONLY!
Do I need a Motor with a wider arc than a Satcontrol SM3D22?
SG2100 will not work with a FORTEC STAR FC120CM dish
