I want to use an older receiver that doesn't send power to the lnb.
I plan to locate it approx 40 ft from the 'master' receiver. I believe that 40 ft would be too far to run a loop out coax?
Would the following power inserter fit the application?
Installed at the ground block at POE. Slave coax would only need to be about 12 ft there. Master receiver on the dc passing side. Slave receiver on the non passing side. (with a dc block)
Would this injector work?
I've been googling.... but more confused than ever.
EDIT: I forgot to add that my satellite positioners are stand-alone, NOT receiver controlled.
Holland Electronics Power Inserter 2-2300MHZ
The HRF-PI power inserter from Holland Electronics allows amplifier powering through an existing output cable.
www.techtoolsupply.com
