losing signal after a short run time | SatelliteGuys.US
skip.c
8
SW Fl
I installed a second receiver for a customer , everything seemed fine but now they say that it runs for a few hours then goes into a "searching for signal " error 771 /772
I was there Thur and changed the cord from the wall to the receiver and it came right up so I assumed that was the problem
I called Friday and they said nope its out again
I'm thinking that to bring it up its a matter of removing the feed cable for a few minutes then reconnecting
the original receiver off the dish is working just fine
this is the receiver I used
DIRECTV - Receiver with DVR
Model: R22 | "
DIRECTV - Receiver with DVR - R22
heres what the LNB says
Eagle triple feed Multi satellite LNB
18x20 dish DTvp3
lmal 4 outputs
bad receiver ?
Bad LNB?
Bad Connector ?
any guidance is most appreciated
Heres a link to the thread where I had inital install issues
http://www.satelliteguys.us/dish-network-forum/173311-need-guidence-installing-second-reciver.html
Try a different output from the dish.
I assume that the correct dish type was selected when the receiver was setup, right?
That's the Phase 3 dish used to receive the 101, 110, and 119 sats.
no setup It auto selected and started playing
should I go in and do a manual setup ?
Does HBH-SA receiver have an ATSC tuner for antenna?
Slimline AU9-S and HD-DVR (HR-22)
