I have just relocated and moved my equipment to the new place which I sort of suspected I would have troubles with due to trees,but after all was installed I had almost equal signal on all 3 sats.
After a couple of weeks with not being touched I have lost 129 altogether. In this "holler" where I live there are other working Dish installs on the Western Arc and they are all pointing at the same foliage I am.
I have tried masking out all but the 129 lnb on the triple with aluminum foil but I can't seem to get any response on 129 from the Hopper3 or my meters when I try to tune that lnb to 119. I have signal in the mid and upper 70's depending on the transponder but not a smell on 129. I can't understand the LNB just quitting on one sat but guess anything is possible. Has there been a failure record on these lnb assys that anyone is aware of.
I did installs for several years and ran into tough ones similar to this but never had this much problem straightening them out before! But then again I have been out of the loop for a few years also.
Any ideas or suggestions appreciated as I would like to have some HD back in the new hut again
Regards,
Wayne
Regards,
Wayne
