loss of signal message: wing dish / signal is good | SatelliteGuys.US
i4tas
791
4
Northern USA
my setup is 129 119 110 via 1000.2 dish triple encased lnb
I added 77 for hd locals with a wing dish (DP Dual lnb) and it goes into lnb in port.
all sats come in good and check switch shows all 4 sats.
If reset the box and immediately tune to a hd local channel on 77 it works great and will keep working great, but if i change to another channel on anther sat or ota and watch that for 1-3 seconds and then hit recall to go back to my 77 channel the complete signal loss screen comes back.
there are no issues flipping between 110 119 129 channels
receiver is 211k
any ideas?
I setup my 211K system a few weeks ago with a mixture of recycled equipment I acquired over the years of being a satelliteguy. I tried a combination of dishes and switches for the EA sats. In my case I had a complete signal loss screen a few times initially and was caused by my mixture of Legacy, DP and DP+ components. Once I figured that out, it's been great. That problem might have been obvious to a DN guru but I'm a new convert.
LNB for sat 77 installation
Dish pq vs direct
