Lost it for a little bit, ok now.Did anyone else lose 129?
No, the satellite is still sending you a signal. It's just the satellite isn't receving a signal so you see nothing.When the upload site loses signal, should my download signal strength go down?
If the signal cannot get up to the satellite you're not going to get any signal downWhen the upload site loses signal, should my download signal strength go down?
Contact Dirt or call Dish.the satellite is not sending me signal or my receiver is bad or my dish is not pointed correctly. I checked all the connections and I can still get the ota channels. this happened several times for a minute in the last couple of days. now it is gone. when I check satellite signal with the receiver, I get no signal. it came back several times, then lost it all now. I have switched to the c band satellite now for various programs. chas
Which of you two supporting founders do I believe?
Limited time offer
