Lost 99w AKA..... | SatelliteGuys.US
Lost 99w AKA.....
freezy
960
Land of Sky Blue Water
Galaxy 16 & Spaceway 2 & DirecTV 11 at 99.2°W
Between my Azbox EliteHD not being able to blindscan or my Coolsat 6100 not being dvs-s2, mpeg-4.... etc ...able
I can't find 99w anymore. I had the abc backhaul pic of the US Capitol but its gone. What are the pids for that?
Are these TPs on 99w ?
11874v4983
11909v1493
11854v4983
Just did a scan on my X2 and here is what I got.
11805 Vertical
SR 3978
VPID 0033
APID 0034
11785 Vertical
SR 3978
VPID 4194
APID 4195
11820 Vertical
SR 4622
VPID 0512
APID 4113
11809 Vertical
SR 3978
VPID 0033
APID 0034
The news feeds on 99W Ku have always been terribly weak for some reason, at least at my location. Even the fixed-location feeds. I suggest that the OP hook up the AZBox and aim for the DVB-S2 Russian/Jewish mux instead, it's really strong.
I found 99w with those pids. I was getting too much bleed from 97w.
My motor is a Digiwave 1 button sg2100 I bought from Sadoun years ago.
I have tried several times to reset everything on the motor and my coolsat to get usals to work...no joy. It always picks a spot 4 degrees west of where it needs to be.
There is absolutely nothing wrong with my arc. I can get 30w, 93w and 125w no problem... and further west but they seem to go away...like Boom!
I had my Azbox slaving off my coolsat. I moved it to a different room with my big tv and connected to the spare LNB connectors
If the motor is always 4 degrees west it's an easy fix, set the location 4 degrees east of where the sats really are. eg set galaxy 19 (97w) to go to 93w. I used to do this with a circular lnb beside my linear that was 6 degrees east of centre.
