Lost all quality on G10R | SatelliteGuys.US
SATisfied
286
Lineboro, MD
I don't know what's happening, but lately I am getting no signal on G10R. My dish is fixed....I know it hasn't moved. I was getting quality of 56% on 11800 just last week. Now nothing. Anyone else having problems?
no bad weather in Little Rock so you can cancel that ouot
Checked mine and its working fine
Do you get any transponders at all on G10?
G10R Fine Here!
SATisfied,
I just checked on mine and 94% on 11800 on a eye-ball temp setup at best just for 10R K tonight!
Weather here has been rain on and off and heavy at times for the last two days.
All TP's strong here on G10R K
My old Fortec Star NA did that sometimes, my fix was a quick power off from the back or unplugged it for about two min, plugged back in and back to the oldies TV! Possible might have bumped a setting in the set up menu? Check all your settings again to make sure that something did not get accidently changed in your installation set-up menu. I have been guilty of that one once or twice! :)
Hope you get it worked out!
Kevin
OK, I now have signal again....didn't do anything other than power off (as I normally do when done watching tv...to conserve electricity), then back on. I made no changes to antenna setup. It's now working with quality on all 5 tp's. Thanks for everyone's input. Sorry for the late reply.... I haven't been online the last couple of days.
Programming Note
what do you have for your FTA setup dish wise?
