lost ALL satellite signals on 2H/2J. Do I need to replace Duo Node? | SatelliteGuys.US
davelanton
16
New Jersey
Woke up to find that all of my TV's are showing "Acquiring Satellite signal" message. Tried restarting the Hoppers, no change. DVR playback is fine, so my guess is the Duo Node failed?
I am a new customer for about 6 months, and I pay for the monthly maintenance. What's the quickest way to get this fixed?
First, unplug everything. After 10+ seconds try replugging everything. While rebooting, check that all coax is tight and nothing has knocked the dish.
No luck? Call Dish ask for tech support.
Can you Rename External Device1 EHD
Dish Rated as Worst Company to Work For by Employees
