Lost the 101 sat | SatelliteGuys.US
Lost the 101 sat
VewDew
167
Northern California
Hello,
I turned on the tv last night and switched to Fox Soccer channel and got a searching for sat message, and after checking into it a bit, I noticed that I have lost quite o few transponders from 101. I think it might be my zinwell 6x8 switch going out but not sure. Is it possible to plug directly into a receiver from the dish with out going through a switch?
Thanks for your help guys.
Hello,
That depends upon how many receivers you have in your house, and whether or not you have a wing dish installed.
For testing purposes, yes, you can run the cable directly to your receiver and see if the switch (or more likely a connection at the switch) is bad.
Did you lose all of the odd or even transponders?
Yes it looks like I lost all of the odd transponders, although some of the even ones are out as well? Could it be a bad LNB?
It could be, but it sounds more like a bad connector on the 13VDC inputs to the mulitswitch....provided there isn't a splitter anywhere in the line.
I would check the connectors on the multiswitch for corrosion and such.
Thank you for your help. I hard rebooted one of my receivers yesterday and it couldn't get any data from the sats until I removed it from the switch and connected it directly to one of the lines coming from the sat, so I think there is definately an issue with the switch.
HD DVR, standard DVR -- question
ANY UPGRADE FROM 0x4062 ANYTIME SOON?
