Loving Life | SatelliteGuys.US
Loving Life
bobthebuilder1966
8
North Branch, MN
Having some problems with a install I did at my brothers house. Still new to dish network so would love any input I can get.
This is the current situation:
Equip......Receiver 625
Dish 1000
DPP Twin
DP dual for 129 (which I don't need for the box but put it on anyways)
Check Switch.............
1 2 3
129 119 conn
ok ok x
twin twin dual
Dish Pointing.............
Tuner Transponder Satellite Strength
1 19 119 91
1 22 129 59
1 22 110 0
Current alignment.....
Azm Elevation Skew
216 31 114
Gave up on my meter couldn't get the same number twice on anything...
tried moving 10 degrees which was suggested before but then just lose them all....:(
Would need zipcode to confirm elevation and skew settings. You are seeing 129,119 with the dpptwin instead of 110 and 119. If you are behind the dish you need to rotate the dish to the left to try and correct.
How Often Does the DVR 625 Phone?
Bad DPP44+ Switch?
