Low or no transponder levels... | SatelliteGuys.US
stangman39
3
A few years back I wasn't getting any signal or channels. Transponder levels were 0 or very low...39 or so. Had a non DTV tech come out and he replaced the LNB and everything was back to normal. Same type issues started about a week ago. I ordered a new LNB online and got it today.
Got signals back but still very low and can only see a few channels. Transponder levels are still low...39 or 49 at best. When I use the guide and press in a local channel...2 or 4...the guide usually auto goes to channel 100. The few times I can actually see channel 2 on the guide and I select it...when I got to channel 2 it brings up "searching for signal."
We had some rain last week and I lost the signal all together...next day it worked ok but over the past few days we didn't have any rain and it was warm and sunny (today it rained but I had no signal prior to today).
I'm guessing I'll need to pay a tech to come out again...but any ideas before I do?
Thanks,
Mike
First of all, you need to check every connection and as much cable as you can see for damage, corrosion, etc...
Then check that the mast is plumb and the footplate is still secure. Then check your dish alignment. You may also want to want to verify that your LOS is still clear.
I think you may just be out of alignment, try turning the dish 'very slightly' and slowly while watching the meter (or having someone tell you). Keep that old lnb - it may not be bad if the dish was just out of alignment.
First HR20 Freezes, now new HR21 Freeze. Anyone else?
Signal strengths
