Hello again all. Once more I am here to ask a silly question (though not as dumb as the DSL comment
) and possibly learn something. Here we go....
Had an upgrade done. A DP Quad installed in place of a Leg Quad. Two lines run to a DPP 44 switch, 2 lines run directly to a 522. From the DPP44, 1 line to a 625, one to a 510 and one to a 508. Before the upgrade, my signal strengths were, at the low end 85-90, with some over 120 (both on 119 & 110) on multiple transponders. Since the upgrade, the best I'm getting is 108 on either sat (although the spotbeams still come in at 125) but on some transponders I'm only getting 50-55
. I never had anything that low.
Up on the roof I go, check to make sure all is tight, try to use the signal bar to tweek it up a bit. No dice. Transponder 19 on sat 119 started at 98 and finished on 99.
The big quastion: Will I see a lower signal on all the receivers because of the DPP44 switch setup? Is it true that the dual receivers cause a lower signal to show (That's what the installer told me!
)? Any help/advice you can give would be appriciated! Thanks again.
