Mark2074 SatelliteGuys Pro Original poster Nov 3, 2004 296 20 Toronto, ON Nov 8, 2014 #1 I can't get a signal anymore. None of the channels are coming in. Am on the only one?
KE4EST SatelliteGuys Is My Second Home Staff member HERE TO HELP YOU! Lifetime Supporter Aug 9, 2004 27,021 7,345 EM75xb Nov 8, 2014 #2 Those channels go off for a few hours at a time periodically. Check back in the morning. I can't test right now or I would.
Joe DC SatelliteGuys Family Aug 19, 2011 104 10 Cana,Va Nov 8, 2014 #3 If you do a rescan when LPB is blank you will find that there is a sporting event on the same transponder using different symbol rates or id's.
ray224000 Balvenie is the way! Pub Member / Supporter May 4, 2014 302 108 North Texas Nov 8, 2014 #4 I learned how to paint on Create this morning.......LPB was fine. However it was off last night. That is just the way they roll.......
Mark2074 SatelliteGuys Pro Original poster Nov 3, 2004 296 20 Toronto, ON Nov 8, 2014 #5 Actually I did a rescan this morning and they came it after the scan.
danristheman SatelliteGuys Pro Jan 25, 2011 3,146 1,142 85w Nov 8, 2014 #6 They do leave give it some time they will be back I have had the same problem. They will have to be on for masterpiece theater Sunday night.
