Luken Gone? | SatelliteGuys.US
Luken Gone?
Si.
18
5
London Ontario Canada
Luken channels on AMC-3 have completly disappeared on the manhattan receiver Florida channel and lottery channel still come in strong on that bird and are normal on other sats. My cheap Chinese receiver will get brief flashes of 60% and quality around 35% the drop to zero on revin or retro TV. Has somthing happened to the bird ? is anyone else having the same problem or is my LNB failing?
Thanks fo any advice
Si.
:welcome to the forum Si. My first bet would be to power cycle the receiver. Unplug the wall wart and plug back in and see if it still has issues.
Yes did that . Spoke to Manhatten repair tech with same suggestion plus factory reset and firmware update. My question , anyone else having same problem ? If not then my dish may need service.
Thanks Si.
10:15 P.M Mountain Standard Time and is booming in fine here on the SAB (could be called an Amiko A3). So, it may be that you need some tune up work.
Good luck with it.
Edit: Just reread your original post. They are now on SES 2 at 87W.
Digipower SG2100 DMSI SUPPORT
