LyngSat Atlantic Ocean Satellites | SatelliteGuys.US
PopcornNMore
3,635
128
Gibsonia, PA
Living in Florida, I currently receive Amazonas at 61 degrees and PAS 9 at 58 degrees very well.
Can anyone receive any satellites past these two?
I still have room for my dish to move and was wondering if I could possibly pick up anything on Intelsat 707, 705, PAS 1R or PAS 3R? Or would the footprints be off for my area?
I may be able to get some feeds off PAS 3R.
11992 V
tp 10
(feeds)
DVB 5632-3/4
12000 V
tp 10
(VYVX feeds)
DVB 6430-3/4
12035 V
tp 12
(feeds)
DVB 6620-3/4
check the footprint to the right of the transponder on Lyngsat
T11 (37.5) and Hispasats (30) can be picked up in MN with no issues :)
Most the others between 30-58 are Europe or S America
I receive Hisapat 1C & D real good here in NC. I can't go any further east, it is at my limit. Quality is real good around 75% on most channels.
If you have C-Band, there's a ton of stuff on NSS 806 at 40.5° west. You'll need an "international" LNB that can do circular (L/R) polarization.
If you only have Ku-Band, you should be able to see 37.5, 30, and 15 without problems, as long as your view to those sats are not obstructed. You might have trouble getting the motor all the way to 15, though.
Still struggling for G10
Helpppp
