Mad Money timer not working? | SatelliteGuys.US
akaArturoK
15
Western NC
I have a timer to record Mad Money from CNBC M-F at 6pm ET. Suddenly it has decided that all the episodes are duplicate events and has stopped scheduling them. Short of recording "all episodes," which will record duplicate episodes at 6 and 11pm, I guess, is there any fix?
EDIT: Never mind! Several minutes later my 722k showed the correct schedule.
Guide data is very jacked up the last month. Not shocked at your issue, and yes, you will just need to set all, or manually override all those cancels. I have a number of shows set to record only new, and constant for the last month it is recording stuff from earlier this year and in some cases 2006.
Guide data accuracy is a huge issue related to customer experience. I don't understand why it is simply accepted by Dish that the provider of this data does such a bad job.
Try changing the timer to daily for the time you want it and see if it records every day. It will of course skip the weekends, since they don't probably show it on weekends.
922 forgetting recordings again.
