Did anyone's system go through a major update last night i think the new update is x-01799 something like that i'll look later on today. but everything went through a reboot.
I have the HS-17 with 3 4k mini's. it did a major update last night the system entire shut down and rebootedNot mine. My HR54 is still on 0x16db from 6/23.
had it since aprilIs this particular recvr a Newer one for you ?
Sometimes new ones will do an update to catch up to the correct software, usually it happens over night.
Hmmm ...had it since april
just this one timeHmmm ...
Has it done it at all other than that 1 time ?
If not, I wouldn't worry about it.
If it IS and continues to reboot, thats a problem.
I think it just needed an update and now your ok.
This must be a Client ....Ok the newest software version. Is 0x1799
yep that was for the mini my server software is 0x17a5. wonders if the update for the mini had something to do with things breaking up and pixelizing seems to have helpedThis must be a Client ....
Your Clients don't get updated as often as the main part of the system, which would be your HS17.
Your HS17 should currently be at 0x16DB
Limited time offer
